Intermittant clutch engagement?
95 F-150 351w 5spd 4x4.
Truck is driven on weekends, maybe 15-20 miles per week.
85k original miles.
Every now and then it will act like the clutch isn't engaging. Push the pedal in and go to change gears and it's like you haven't engaged the clutch at all, hard coming out of gear and grinds going in, especially in reverse. Pumping the clutch a few times seems to get it to go into gear.
Will do that a few times and then act normal.
Fluid in clutch reservoir is good, pulled little boot to confirm.
Strange that it just does it every now and then, no consistency to being cold, warm, etc.
Thoughts?
85k original miles.
Thoughts?
look under the dash at the swing arm that hooks to the cylinder rod. there is a plastic bushing on it that will ware out. after it wares out the cylinder rod will start warring a groove in the swing arm. also make sure the arm is bolted tight to the clutch pedal assembly. You will need a flash light to see up under the dash. another place to check is the slave cylinder push rod bushing under the truck. there is a plastic bushing on the end of the rod where it pushes on the through out bearing fork. make sure it is there.
Ok- checked out the bushings/linkage everything looks good, no obvious signs of firewall flexing.
The problem is definitely more common now, almost constant, but if you press the clutch very firmly, almost mash it into the floor it engages ok. There is no slipping on takeoff.
Maybe a pressure plate?
coleboy11
05-09-2014 06:14 PM
