Fuel tank problem
Fuel tank problem
Have a 1989 F150, 4wd, 6 cylinder Pick UP. I recently installed a front fuel tank with pump and sending unit.
Took a ride and noticed unusual fuel consumption. Scratched my head and did a lot of checking. Kept refilling the front tank.
Today I came home and noticed that there was gas leaking from the fuel inlet of the rear tank which I was not using. Fuel gage of rear tank reads empty so that is a problem needing fixing later.
Why is the fuel being transferred to the rear tank? Other than the gage sending unit, there is nothing wrong with the rear tank that I know of.
Exactly. ....and a dual function reservoir that controls fuel flow. That's why I am saying the issue is not a bad Fuel Delivery Module (FDM) inside the tank. If your truck was a 1990 and later then I would agree that would be the cause (bad FDM).
courtesy of Steve83
Fuel Diagram (gas engine):
courtesy of Subford
The frame mounted Dual Function Reservoir is identified as the Mechanical Selector Valve/Reservoir in the diagram above.
dziwei
06-15-2018 08:53 PM
cornbinder
11-12-2010 10:29 PM
Penrider
05-10-2010 03:02 PM
AutoHound
02-18-2009 04:52 AM
