Need Help with FUEL PROBLEM
Old Jul 8, 2004 | 06:47 PM
vandya's Avatar
vandya
I have a 1993 F-150 4.9 with dual fuel tanks. The problem is with the front fuel tank. The fuel hand is on empty, even when there is gas in the front tank. When I switch to the rear tank the fuel hand will register correctly. Although the hand is on empty, the truck will run fine on the front tank (It has about 3/4 of gas in the front tank). Does anybody have a clue of what may be causing this problem and if it is an easy fix? Thanks!
Old Jul 8, 2004 | 07:25 PM
ATC_250SX's Avatar
ATC_250SX
Sounds like your sending unit has bit the dust, time for a new one.
Old Jul 8, 2004 | 08:03 PM
thomadm's Avatar
thomadm
My 90 F-150 has the same problem, front tank doesnt register and the back does. I just fill up and use the front first and switch over to the rear after 215 miles. I cant see dropping the tank just to replace a sender. Ill wait till the fuel pump goes.
Old Jul 9, 2004 | 04:16 PM
ATC_250SX's Avatar
ATC_250SX
Do you have to drop the tank? if you get in there you can get to it without dropping the tank, from the pass. side, although i may be able to do this just because i have a smaller muffler further back, but you could always take out the drive shaft and get it from there. i think youd be able to wiggle it out from its hole.
Old Jul 10, 2004 | 11:12 AM
vandya's Avatar
vandya
Fuel problems!
Thanks for the info, I'll get to it right away. I can't stand not having anything to work properly, therefore, I must fix it!
