Dash Lights & Hard Shifts
New to me F-150, Flareside, 4x4 (push buttons on dash & auto hubs), aod, 5.8L, reg cab, has full gage pkg (tach, oil, alt, fuel, temp & speedo), aftermarket alarm (butcher install).
The following problems have occurred: Airbag/SRS light blinks code 32 (driver side airbag circuit high resistance or open), OD light blinks (didn't notice a pattern), no horn, no interior lights, no speedometer, no odometer, all other gages work, hard shift 1-2 & 2-3, no 3-OD shift, trans fluid red & full.
Pulled and checked all fuses (none blown but replaced a few w/ correct amp), pulled apart dash & started tracing wires for alarm (going to remove alarm & rewire factory harness), no signs of an accident ever.
HELP!!
HELP!!
By all means remove the alarm! As for everything else I can't be much help but My 97 did have a speedo not working. A fuse is not your apparent problem but with mine the guy before me had switched the interior light fuse so the interior light/ bed light could be shut off for doors being open for long periods of time. When this switch was in the off position the speedo would not work and the trans did all kinds of wierd stuff. I was told there is a speed sensor somewhere that talks to the speedo and the trans and together they make it all work. This could be a place to start looking.
I borrowed a Snapon scan tool from a buddy to read trans codes, now I'm having trouble finding the OBD port. Going to borrow an air bag simulator from another buddy to bypass the clock spring under the dash to confirm the clockspring is bag. Any other suggestions??? In process of removing alarm.
First, we need to figure out what you really have.
The AOD was never mated to the 5.8L in the F-150. Also, the AOD doesn't HAVE an OD light. I'm pretty sure you have an E4OD. If I knew the year of the truck it would help. There is also a data decal in the driver's door opening. Under TR it will have a letter. "E" means E4OD.
Before tearing everything apart you need to know what codes have been stored. A cheap OBD-I reader will work on this. You can also use THIS method.
Once we have the codes we can direct you towards what's wrong.
It's under the hood. Look at the link, above. It has a picture of what the connector looks like. It doesn't look at all like an OBD-II connector.
Sorry, didn't realize I forgot the year when I originally posted. It's a 1995 F150 Flareside. I'm not a transmission guy & thought AOD meant all Automatic Over Drive transmissions. Yes, I believe it is a E4OD as the pan "looks" the same as the Trans in my 97 F250 Diesel 4X4. Also thought the OBD port was under dash like my 97. I will go get the info off the door tag & post what I find (poring down rain right now). Thought it had OBD II but it doesn't, it has OBD I? or EEC-IV under hood and the scan tool I borrowed wont hook up to it. I stopped @ auto parts store & they had a scanner that would plug into it but says on pkg that it will NOT do 1995 Truck w/ 5.8L & Auto trans??? Found my Haynes manual & it shows how to retrieve codes w/ jumpers & volt-ohm meter. Will try that when weather clears. Thanks Mark for info.
Check fuses #8 and #18(in cab), those fuses supply power to dome light AND PSOM(speedo) memory. Fuse #18 is switched power to PSOM and few other things like SRS(airbag) controller, 4x4 control?...
If your dome light works then the PSOM should be getting memory power to it
Did you also check the BIG fuses under the hood in the relay/fuse box? One or more could be bad.
Rain let up some. Checked door jam TR is an E (E4OD). Jumped OBD I, w/ engine cold & not running, I retrieved the following KOEO Codes:
116 - ECT outside test limits during KOEO or KOER tests.
636 - TOT sensor voltage out of self-test range.
114 - ACT outside test limits during KOEO or KOER tests.
And the following Continuous Codes:
212 - Loss of IDM input to PCM or SPOUT circuit grounded.
452 - Insufficient input from vehicle speed sensor.
OK, so I've been looking for what some of the codes mean & I've failed. ECT = engine coolant temp sensor, IDM = injector driver module, IAT = intake air temp sensor, PCM = "computer"/primary control module, ACT = ?, TOT = ?, SPOUT = ?, PSOM = ?.
I'm no a computer guy so pardon my ignorance but I don't want to throw money at it OR pay someone else to replace or diagnose parts if I am able to do it. Trying to figure out if I should keep it & fix it, turn it over to a mechanic & pay to have it fixed or drop back & punt (sell it & recoup some of my $$$).
Thanks all for the help.
Engine Coolant Temperature outside test limits during Key On Engine Off or Key On Engine Running tests. You ran it cold, it's supposed to be warmed up.
Transmission Oil Temperature. You ran it cold, it's supposed to be warmed up.
Air Charge Temperature. You ran it cold, it's supposed to be warmed up.
Injector Driver Module (only for diesels.) SPark OUTput (gas engines.) This is the circuit that controls the spark advance. You need to fix this one.
This will cause all of your transmission problems. This is your biggest problem.
The 212 code most of the time someone replaced the ICM with the wrong one. They installed a gray one and you need the black one to get the IDM to the PCM.
The 452 sounds like a power or ground problem.
Make sure you have a good ground from the NEG post of the battery to the fender the Body ground. This is the most important ground on your truck along with the engine block ground. The frame does not need to be grounded as it is only used for trailer brakes return and trailer lights.
PSOM: Programmable Speedometer/Odometer Module.
ICM: Ignition Control Module.
IDM: Ignition Diagnostic Monitor.
IAT: Intake Air Temperature. (ACT acronym not used in 95 and replaced by IAT)
TFT: Transmission Fluid Temperature. (acronym was TOT in older trucks)
SPOUT: Spark Output. (Spark Output, Desired spark timing information sent from the PCM to the ICM)
The black ICM so you can get the IDM information to the PCM:
.... aftermarket alarm (butcher install).
HELP!!
HELP!!
With all fuses good, I think its time to pull out the instrument cluster and see what's behind it with the wiring. Looks like the butched alarm install munged a few wires around the steering column and/or behind the cluster.
Without the speedo(PSOM) sending speed info to the ECU you will get hard shifts and OD light blinking along with the VSS error code.
