Is this D44 a High Pinion?
Received 3,108 Likes
on
Assuming it's a front axle, turn the pinion shaft CCW (as you look at in in that picture). If the axles turn forward when you do that, then yes, it's a high pinion. If they turn backward than it's an upside-down low pinion. (If it's a rear axle you can do the same test but turn the pinion CW, forward is high pinion, backward is upside-down low pinion)
This help?
I don't know if they are stock discs on it or not, if original it would be 77'-78' wouldn't it?
What I want is a HP D44 HD with 1/2" thick tubes.
But I've read that the 1/2 ton HP D44 has 3" diameter x .250 thick tubes and the 3/4 ton HP D44 HD has 2.75" diameter x .500 thick tubes, then saw that the 3/4 ton HP D44 HD was 3" diameter & .500 thick tubes not 2.75" x .500.
So not sure what the difference what the 3/4 ton HP D44 HD has and whats different than the 1/2 ton HP. But then things change by years too.
So what is difference between a 3/4 ton HP HD and a 1/2 ton HP and how do I tell the difference?
PS, is this a 77'-78' with the two piece tube and cast radius arm piece that the tubes slip into?
Cheers, Allen
Cheers, Allen
on
OK, I'll be going to pick up a NP435 & 205 Tue, I'll check it out & get some more info.
Does this one have the 1/2" thick tube and are the tubes one piece with the radius arm bumps welded on or is it the two piece thin wall tubes with cast piece between them?
If is the thin tube or two piece tube but the center housing is the same as a 3/4 ton version I'll get it and re-tube it with 1/2" tube and put new Solid Axles inner C on it, can turn them then too.
I'll be using Chevy 8 lug outer knuckles, hubs & calipers.
Cheers, Allen
Cheers, Allen
on
benmoderow
32
02-23-2010 10:14 PM
Rogmatt
07-03-2008 07:27 PM
3Mike6
08-09-2007 03:03 PM
