Excessive Exhaust Smell in Cab During Extended Idle
2015 6.7 KR... when idling for long periods of time the cab starts to smell like exhaust.
I've also noticed when standing outside the truck with it idling (not in regen), it freaking stinks, bad! My 2003 never had this problem and idled for days (literally).
Possibly leaky gasket here or just the nature of the 6.7?
Is this with the air/heat (no recirc) turned on or all of that off? I know with my truck, the recirculation option will only stay enabled for about 10 minutes with the heat. So if the truck is idling any longer than that and the recirc turns off, the cab fills with the smell of the exhaust. Unsure if that's changed with 2015. If you have air with recirc on, cab should be fine.
If you mean the smell doesn't smell like diesel, that is how the new emissions (SCR) diesels smell. It doesn't smell good and certainly not what your 7.3L smelled like.
In fact, if anyone smells the old diesel smell on a stock 6.7L, that would be an issue.
Exhaust smell inside the cab is not normal. However on a new truck you can get a hot exhaust smell that might waft into the cab during or right after a regen.
That said, you should NEVER subject these motors to extended idling. It's only going to cause big problems down the road. Modern emissions systems on diesels do not handle extended idling very well at all.
If you're already subjecting it to a massive amount of idling, you may already be having early signs of emissions problems if you're getting unusual smells. Or maybe there's a defect.
Ford idled trucks at -40*F for a couple weeks. Posted video on youtube about the testing.
Yep. There is also a recall addressing this but don't have the specific info on hand at the moment. Anyway, take a look at this video. I know there are more videos on this subject but this is the first one I found with limited time looking...
Thanks
Maybe I'll find the TSB too
Marketing videos aren't always representative of real-world results. Keep that in mind when you have to replace your DPF far sooner than the stated service life.
I found a couple TSB on this issue - not necessarily easy fixes though as the vid shows
11-6-22
and
10-22-9
.....and found here at least on the '11s: Fulltext TSBs - Ford-Trucks.com
11-6-22
and
10-22-9
Exhaust in Cab?
