Help Identify Level or lift?
I posted this in the general Super Duty Forum as well-hope its ok:
Hi all. I recently did a tire swap and went from the factory 18s with 33's on it to the RBP 94R 20s with 35X12.5 tires. I was told they would not rub and of course the do at full right turn only on what appears to be the bumper bracket. So i am looking to lift my truck. The problem is i bought it used (2012 Gasser) and it appears to be some type of level or lift but i am having a hard time with the size. The Front sits 1" taller than the back and the back has the factory 2"block and another 2" block stacked on top of it. The tire guy swears i do not have a level/lift but how could the front sit taller than the back with an additional block added (sagging leafs?)???? It did have different shocks on it than stock but i couldn't tell because the label were worn. Can anyone help? I want to do a 4 inch but if that is only going to give me another 1" clearance than i might as well do the 6 inch lift. Thanks in advance!!!
Ford F250 1.5" Leveling Kit 1.5 inch
Rain Desert-i did not see a spacer or anything. Some have said that it may be the snow plow springs sitting higher because of rear sag. One other thing i just thought of...could it have the RC 1.5 leveling springs on it? It has aftermarket shocks on it plus a 2 inch block on the rear. I am now thinking he may have just installed the taller front spring with new shocks to level it with the rear block and then the springs started to sag? I am just guessing really. My lift goes on Tuesday so i guess i will find out if the back sits 2-3 inches higher than the front or only 1-1.5 inches taller.
So it turned out pretty good. Getting rid of the block and going with the leaf on the axle is a much better drive. Now the back sits 1.5 inches higher than the front. So, the either the previous owner put a 1.5 inch coil level on it or the leafs were sagging that bad. Either way i like the way it turned out.
Rear Leafs=6 inch lifted Skyjacker Softride Leafs
Front=3 inch RC lift (maybe longer coils not sure)
Thanks for all the help and suggestions!!!
whitebassbenny
10-01-2007 08:59 PM
