6.2L V8 Discuss the 6.2L V8
Adding some mechanical guages
Old Dec 25, 2015 | 09:45 AM
flyingtexan's Avatar
flyingtexan
I'm adding three gauges, all mechanical, Oil, Air PSI (onboard air) and Volts (dual batteries conversion). Curious where the oil sending unit is, or other oil ports I can tap off of?
Thanks
Old Dec 31, 2015 | 10:56 PM
Unclemark's Avatar
Unclemark
I dont know for certain but I dont believe you can run a mechanical oil press gauge off of the factory electronic sending unit. I would think it needs its own oil gally port in the block and so far as batteries are concerned once tied together they will give the same volt reading regardless untill you seperate them unless you run a dual batt isolation block thingy lol
1959_f100
Jan 31, 2009 11:56 PM
92302FREAK
20
Feb 14, 2008 07:10 AM
diverstroker
Jun 9, 2007 08:13 PM
StealthWyvern
May 20, 2007 09:23 AM
seawulff
Jan 17, 2006 04:54 PM
