Factory engine block heater
Huh, now that's interesting. Just took a look at the order guide and found this:
Looks like if you live in Alaska or the upper midwest it's standard, all other states need not apply. Very interesting.
I've never seen one work that way, but the only ones I've had before were on diesel models. But every one I've ever owned or read about is comprised of a heating element that replaces one of the block casting plugs and is immersed in coolant. I'll have to do some more digging, but I'm assuming that's what this one is.
Looks like it. From the 2013 Order Guide:
Originally Posted by 2013 Order Guide
ENGINE BLOCK HEATER
Standard and only available in the following states: AK, MN, ND,
SD, MT, WI and WY. Other states available via FCSD.
NOTE: (Fleet Only) – Engine block heater (41H) available in all
states with valid FIN code.
They are common here in Northern Minnesota, The Eco uses a immersion type heater, It screws into the block cooling jacket, most are 400 watts on gas engines,
Most of the newer cars are also equipped with a thermostatic cord so the block heater won't turn on until the cord temp is around 5 to 10 degrees, I suppose it saves energy.
Here it Zero-Starts catalog, this is the brand most use up here.
Phillips & Temro Online Parts Catalog
Originally Posted by 2015 Owner's Guide, p 162
Using the Engine Block Heater
Make sure the receptacle terminals are
clean and dry prior to use. Clean them with
a dry cloth if necessary.
The heater uses 0.4 to 1.0 kilowatt-hours
of energy per hour of use. The system does
not have a thermostat. It achieves
maximum temperature after
approximately three hours of operation.
Using the heater longer than three hours
does not improve system performance and
unnecessarily uses electricity.
Josh
Even still, the 6.0 block heater only raises the coolant a certain amount over ambient.
Josh
I have heard of such systems for use on heavy equipment. they generally have a pump and a diesel-fired heater from what I've seen. I don't think that's a common system anywhere but the arctic, and even there, if it's truly cold, those machines will run 24/7 until the job is done.
Back in the day when I lived up in north-central Minnesota (near Brainerd), everyone used circulating tank heaters. It was a small unit a little larger than a Fosters beer can. You hook it into one of the heater hose lines, and it heats and circulates the coolant.
We had a non-heated garage, but we rigged up a timer that would turn on all the tank heaters at OH-dark:30.
It was wonderful to be able to turn on the heat in the vehicle and get warm air from the git-go. Backing out of the driveway, I would already be warm, but I still had the square tire problem until those old nylon-chord tires started warming up.
#28
Diesel was cheap then, now it's different. Plus electronic controls etc make cold diesel starts easier.
I may look into retrofitting block heater in my 5.0, or I may not.....
Josh
#29
Bullitt...you don't have to do any retrofitting to your 5.0, just order a block heater from Ford and install it. I live in North Pole Alaska, all of the vehicles have block heaters, battery pad heater, oil and transmission pan heaters. When it's 50 below it's tough on a vehicle. But almost all the garages here are heated so we don't plug in at home.
#30
Josh
