Rim search
Old 11-21-2015, 07:47 PM
orich's Avatar
orich
orich is offline
Have you looked in wheel spacer to adapter over to the pattern you want.
Orich
Old 11-21-2015, 09:30 PM
Gembone's Avatar
Gembone
Gembone is offline
I thought about a small spacer but would have no way to center the wheels.
Unless you might have some options. I don't know if spacers have centering rings built in.
Old 11-23-2015, 08:20 AM
anthony myrick's Avatar
anthony myrick
anthony myrick is offline
Old 11-23-2015, 11:17 PM
Ddaybc's Avatar
Ddaybc
Ddaybc is offline
Have you checked with a machine shop to fabricate new studs in the thread pitch and length you want? I don't know what it would cost but it might be reasonable?
Old 11-24-2015, 12:48 PM
Gembone's Avatar
Gembone
Gembone is offline
OK, I think for now I am going to get some adapters to fix the lug pattern. With 1.5" adapter it will also give the truck a better wider stance. This will at least make it safer for the time being until I can find what I truly want on the truck.
These are the ones I am looking at:
Amazon.com: (4) 1.5" (38mm) 5x5.5 to 5x135 Wheel Adapters / Spacers | 1/2" studs / nuts | 5x139.7 to 5x135: Automotive Amazon.com: (4) 1.5" (38mm) 5x5.5 to 5x135 Wheel Adapters / Spacers | 1/2" studs / nuts | 5x139.7 to 5x135: Automotive
Old 11-24-2015, 06:37 PM
orich's Avatar
orich
orich is offline
These are the ones I am looking at: Amazon.com: (4) 1.5" (38mm) 5x5.5 to 5x135 Wheel Adapters / Spacers | 1/2" studs / nuts | 5x139.7 to 5x135: Automotive
Heads up!
I ran some of these spacer adapters for a while.
One thing, I found out is make sure you have a lug socket that fits into the lug nut bore first as my thin wall 13/16 socket was not so thin. But had the wheel off and ready to run the lugs down socket did not go into the bore to tighten the lugs. And found an old spark plug socket the fit in the lug nut bore.
Orich
Old 11-24-2015, 06:42 PM
Gembone's Avatar
Gembone
Gembone is offline
Nice info. I have thin walled flip sockets for lugs in rims that have little to no room. If I need a thinner socket I can borrow or buy one. Thanks for the heads up.
Dr_Gonzo
19
08-07-2015 06:34 PM
truck_girl18
1983 - 2012 Ranger & B-Series
04-06-2008 06:28 AM
loveoldtrux
03-25-2006 12:05 AM
88svt
Modular V10 (6.8l)
01-10-2006 12:34 AM
Quick Reply: Rim search
