Carrier swap?
I believe that an 8.8 ford is an 8.8 ford regardless of the suspension. I could be wrong though, hopefully someone can further answer.
I was wondering because of my hi mileage 3.08 trac loc could use to be rebuilt after checking on prices for new setup 😵 the thought passed me if I found a low mileage trac loc set up it would be considerably cheeper the one thing I've seen that made me question was the explorer carrier has a speed sensor / ABS wheel behind the ring gear thanks for the reply !
???? He's looking to replace his worn out limited slip, so yes he needs the carrier. But ring and pinion gears don't have splines, those are in the carrier, so I'm not sure what your thought is here.
Setting up an 8.8 - The FORDification.com Forums
From what I get in this link is that it will all go together, but the side gears may not have the grooves for the axle retaining clips. So you would have to swap side spider gears.
going slow
03-05-2008 06:02 PM
effie1
07-06-2005 11:44 AM
FordGP
12-01-2004 08:01 AM
