8.8 rear end question
Old Mar 5, 2008 | 06:57 AM
going slow's Avatar
going slow
ive got one from a 88 t-bird. and was wondering if i can use the axles and disc set up from a 92 crown vic.. i know id have to shorten the axles but this would give me disc and 5 lug....it on a very tight budget and i have both these alxes sitting in my garage....thanx in advance.
Old Mar 5, 2008 | 11:14 AM
79Thunder's Avatar
79Thunder
Yes, I think it could be done.
However, shortening the axles and very tight budget probably shouldn't be used in the same sentence.
I think it would be more cost effective to find an appropriate correct width and bolt pattern donor. (ei. Explorer, Granada, etc.)
Old Mar 5, 2008 | 05:40 PM
havi's Avatar
havi
I'll have the Roast Duck
5x4.5 can be achieved by using driver side only axle shafts from a Ford Ranger with 9" drums. Or passenger side only shafts from an Aerostar, mid eighties, earlier nineties. It's a direct swap. the downside is you are still using drum brakes. Only a few 88 tbirds got the smooth surface 10" drums. There's nothing you can do with these that I know of. the spline count is 28. CHE makes adjustable arms for using the suspension that bolts onto that axle. If your car was a turbo coupe, it would already have disc brakes. IMO, the Explorer axle would be better.
Old Mar 5, 2008 | 05:56 PM
tacson's Avatar
tacson
I work part-time in a salvage yard. I say save the hassle and with the explorer Rear axle assembly
Old Mar 5, 2008 | 06:02 PM
going slow's Avatar
going slow
whats the width of the exploror? and what do u mean about the axles and drives vs passangers sides? like im going to have to get 2 of one or the other? is that beacuse its an offset axle?
JimRay
Aug 8, 2011 07:32 AM
Pearlwhite94
Apr 21, 2008 10:37 PM
Pearlwhite94
Jun 27, 2007 02:47 PM
JakeTheSnake
Feb 7, 2006 07:42 PM
Dalamatition
Jul 16, 2005 12:58 AM
