Under Floor Hydraulic Clutch Master Cyl
Not sure what you're asking. You already have a single reservoir hydraulic master under the floor. R U looking for a dual master, power master, power dual master, hydraulic power master cylinder?
Just re-read your post. Are you asking about a hydraulic CLUTCH? I may have mis understood your post.
Last edited by bjmayberry2; 11-18-2015 at 08:03 AM. Reason: Added re-read your post.
I already have upgraded to a power brake booster with double master cylinder under the floor. The transmission is the original 3-speed manual.
We are going to upgrade the power train to a V8 with a modern manual transmission. As such the linkage for the clutch most likely will not work. Thus to use a modern 5-6 speed will need a hydraulic clutch setup. As the truck is still using the original pedals, I would like to keep them. So this now means fabricating a clutch master cylinder mounting that is also under the floor.
We will also add remote fluid reservoirs as well.
Here is how I did mine on a 52, should work the same on a 53-56. Retained the original pedals.
Bellcrank to change the clutch motion from pull to push.
Clutch master installed behind the brake master.
More can be found on my build thread.
https://www.ford-trucks.com/forums/1...-thread-5.html
big ole ford
06-10-2018 07:33 AM
Claybreaker144
01-25-2017 09:31 PM
dbrown13
03-05-2004 05:50 PM
