"Belle" 1952 F-1 build thread. - Page 5 - Ford Truck Enthusiasts Forums
Old 01-20-2015, 08:58 PM
1951 f1 two's Avatar
1951 f1 two
1951 f1 two is offline
1951 f1 two is starting off with a positive reputation.
Very nice work, tagging along to learn how to do it right.
  #62
Old 01-23-2015, 07:26 PM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
Rimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud ofRimrock F1 has much to be proud of
There are few rules when modifying a vehicle one of the most important being, assemble everything first. I didn't follow this rule when I test fit the engine, I left the front swaybar out. On the regular TCI 48-52 front suspension the bar installs behind the crossmember. On the custom IFS it installs behind and slightly above the crossmember. After installing the sway bar I attempted to install the engine, the drivers side was fine but the passenger side has a small bulge in it which hit the newly installed swaybar. This is where it's great to have the help of fiends. Rick, everyone building a truck needs a Rick he is a machinist and a welder and I've never had a job yet he couldn't do modified the pan for fit. Had I caught it earlier I could has raised and moved the engine rearward for clearance but really I would have installed it the same as I did.
Getting ready for front suspension install.
Prepping the rear.
Front control arms.
Lower control arm and swaybar installed, this was a uh-oh moment.
  #63
Old 01-23-2015, 07:31 PM
Rimrock F1's Avatar
Rimrock F1
Another view of the swaybar.
We have contact! On the drivers side there was an inch of clearance.
Another view.
  #64
Old 01-23-2015, 07:45 PM
Rimrock F1's Avatar
Rimrock F1
So off came the pan.
What a Coyote looks like inside.
Since the pan modification was going to take awhile it was on to other projects. This is the bell crank for the clutch, another Rick part. This will allow the use of a hydraulic clutch with the stock pedal.
As installed.
Since I had a lot of other work to do I installed the engine without the pan.
Looks great in the frame, pan or not.
Started measuring the rear suspension for some bushings and locating left to right.
  #65
Old 01-24-2015, 05:59 AM
mkassab's Avatar
mkassab
mkassab is offline
mkassab is starting off with a positive reputation.
Off topic
Mike... I always see your tall iron shooting target, a piece of advice, you're shooting high right!
Mark
  #66
Old 01-30-2015, 10:16 PM
Rimrock F1's Avatar
Rimrock F1
Mark
That's because i'm afraid of the left.
  #67
Old 01-30-2015, 10:25 PM
Rimrock F1's Avatar
Rimrock F1
Rick sent me a picture of Belle's oil pan with the caption. We're committed now
A piece of 2 3/4" tubing and some sheet metal and we had this.
Everything was tig welded once and then tig welded again with silicone bronze rod to make sure there were no leaks.
A little paint and it's good to go.
should have good clearance now.
  #68
Old 01-30-2015, 10:41 PM
Rimrock F1's Avatar
Rimrock F1
I left a little extra space between the rear coil-overs and the crossmember in case I had to adjust the rear end back.
Made a couple spacers to fill the gap.
Also took this opportunity to install the stock parking brake. Should say my wife did, took about four try's for her to get it right but she stuck with it.
While she was working on the parking brake I started on the hydraulic brakes. Lines are ni-cop that's why the strange color.
The ni-cop won't rust, comes on rolls and is easily bent.
I hate doing brake lines and am usually the one who does it for all my friends. When I pressurized the system none of my connections leaked. However four connections on the CPP booster and combination valve leaked. Two days after I fixed them I started getting fluid on top of the combination valve that would then drip on the floor and run for a couple feet (thanks epoxy floor). After a hour long search I found the combination valve had a leak inside one of the mounting holes.
  #69
Old 01-30-2015, 10:56 PM
Rimrock F1's Avatar
Rimrock F1
I also fitted the new driveshaft.
A whoops moment. When they made the drive shaft they installed the wrong rear u-joint. The spec sheet had the right one specified so they paid the return shipping, welded on a new joint and had it back to me two days later.
I also decided to change the routing of the steering. I moved the shaft inside the header. You can see the heim joint to the outside of the header where I was originally going to run it.
Because of the new routing there was a small boss on the block I removed for better clearance.
The other clearance issue with the engine was the oil filter. My solution was a remote filter in front of the engine.
Finally I started fitting up the hydraulic clutch master. With the bellcrank Rick made I was able to keep the stock pedal and geometry.
  #70
Old 01-31-2015, 06:04 AM
mkassab's Avatar
mkassab
mkassab is offline
The Clutch pedal adapter that was made could be marketed... everything looks great!
Mark
  #71
Old 01-31-2015, 09:45 AM
barnfind 51's Avatar
barnfind 51
barnfind 51 is offline
barnfind 51 is starting off with a positive reputation.
You are doing a fantastic Job on your Truck!!That motor should have no problem getting onto the super Slab. Wow !! I learn so much on this site from Ya'll Great Fab work!! Thanks for posting.. I might need to steal your bell crank design.
  #72
Old 02-05-2015, 06:46 PM
Rimrock F1's Avatar
Rimrock F1
Mark
Thanks for the compliments. I now know the Clutch setup works great. I was worried for awhile.
  #73
Old 02-05-2015, 06:57 PM
Rimrock F1's Avatar
Rimrock F1
It's Christmas around our house. The new Griffin radiator came in!
The little flaps open to let air through at higher speeds but close at low speed so the fans pull air through the radiator.
While I was working on the brakes I gave my wife the old radiator and asked her to remove it from the cradle and then prep the cradle.
An hour later she gave me this! Dinner was on me.
A trial fit confirmed what I suspected....
The condenser hit the reinforcing bar on the front.
  #74
Old 02-05-2015, 07:09 PM
Rimrock F1's Avatar
Rimrock F1
My solution was to remove the cross brace and weld in some spacer blocks. The brace was bolted back in. Radiator cradle is upside down in photo.
Fitting before the brace was re-installed. I am moving the radiator to the 6 cylinder position.
Checking the inlet tube fit. I will make a new one for more clearance.
With some modification the factory supplied radiator hoses should work
Engine feed side.
  #75
Old 02-05-2015, 09:03 PM
Gicknordon's Avatar
Gicknordon
Gicknordon is offline
Gicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to beholdGicknordon is a splendid one to behold
If you aren't already planning on it, I would find a way to add a new cross bar back onto the radiator support. The whole front sheet metal is hung off of that support so that cross bar add a lot of structure to it.
Quick Reply: "Belle" 1952 F-1 build thread.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
