No start after new injectors
I recently installed new 180/80 injectors from a small one man shop he has a good reputation I put them in and it had a bad seal so it miss fires and had a lot of white smoke so I pull them and put new seals on them reinstalled them and now it will not fire. I have been cranking for over 2 days only builds like 45 psi that's what the icp sensor says. I have the batteries on chargers they have plenty if charge it will not fire I don't know what to do it ran before I pull the injectors I just don't know there's a intermittent cam sensor code but the tach works I have ordered ipr seals and will install them after anyone have any idea what's happenening?
By any chance you have your valve covers off? If so re check the connections and that the injector solenoids are nice and tight. But sounds like the injectors weren't done right, since you had problems from the beginning of the install, might want to take it as a possibility
If it's only showing 45psi icp while cranking then you have a major hpo leak or no feed. I know it sounds like a dumb question but how much oil is in the truck? Did you check the hpop reservoir? And are you sure. If those two and check out and the ipr oring don't help I would recommend pulling the valve covers off and watch for oil escaping while cranking.
redman84
36
10-11-2011 10:35 AM
Hamberger
02-15-2007 11:15 AM
