1975 Heater control P/N needed
Thinking on figuring out how to replace my manual fuel tank switch with the electric one found on the dual tank, non-AC heater control panel.
Does anyone know the pn of the 1975 heater control panel with dual tanks and no ac.
I believe there is also a solenoid which replaces the manual valve and a harness between the solenoid and the heater control panel;(both of which are available aftermarket).
Assembly drawing of this option would be highly appreciated as well.
Thanks in advance
Tbruz
Thanks in advance
Tbruz
on
I used a heater panel from an 80's or 90's truck and the original switches. Only had to re-wire a wire or two to match the fuel tank labels (Front / Rear vs. original Aft / Fore?), and shave down the mounting posts.
I have 2 none a/c heater controls with all the slide bars/*****, light, both switches and the other side of the connector with wiring.
FYI 5 blade pins on the back side of the fuel tank selector switch.
78/79 duel fuel tanks frame switch-Duralast/Universal 3 port fuel selector valve used with SW48 toggle switch Part Number:*FSV4
Christopher Workman
03-03-2019 09:18 PM
Super Econoline
09-04-2012 03:11 PM
Amphihauler
07-03-2011 02:04 PM
aka rotten
12-18-2006 11:15 PM
hster
10-20-2004 03:16 AM
