Hey guys, I have a 2000 F350 XL, curious about the seats. Mine are currently bench style with the 40/20/40. What seats could I swap into my truck to replace those. Id like to do something nicer than this worn out cloth...
I just put a 40/20/40 seats from a 02 into my 08. Direct bolt in just the wiring was different. You should be able to swap any superduty seats in. The cabs are all the same
seats from sing, extended and crew cab trucks are all the same the extended cab brackets were different in the case of OBS trucks however all seats from 99-2016 should work just make sure you get a seat with a seat belt init from an ex cab if you have and ex cab and if not...well you might just have two belts and get to choose lol.
I did that, replaced the bench in my 99 powerstroke (crew cab) with leather buckets from a 2000-03? took out the in-cab belts and used the integrated belts.
they came out of an ext cab too by the way, and bolted right up.
was kinda nice cause they also tilted a good ways forward if I needed the space or to access things in the back
