Door Striker Plate Screw removal
Thanks abe, let me know what you find.
I'm not in a real rush. I'm hoping to be able to get the truck out for regular, legal drives this spring.
I got the driver's side off. I put some ATF/Acetone mix on them last night. Then today I took my old impact screwdriver set and used a large phillips that seemed to lock in place pretty good. The first two I applied heat and they came out well, the third I bypassed the heat and it came out just fine as well.
I think I will leave the passenger side. It seems in pretty good shape.
The shims surprised me a little. Not sure what they are made of, but they had some backing paper/cardboard on them and they were attached. Shoot hang on.....
OK I'm back. Ran out and took some pictures.
Of course the midfifty shims are chrome too....we will see what I can find.
Received 4,132 Likes
on
I bought the Altman's and wished I'd kept the originals because of the way they function, you can't lock the Altman's from the inside like you could with the originals. Locking and unlocking with a key would be a pain I think so I bought the power lock kit which made it a very expensive upgrade. Things get even worse if you live here in Canada with our crippled dollar.
It is a cross you must bear and it will not end until you sell your truck or die. Other stockers will likely defend the stock latch and I will just smile.
Now I have to figure out what I am going to do with my stock latches this winter.
It's really fun to tinker with old stuff. I enjoy it too. This is one of the few things it is hard to repair on these trucks without buying fairly expensive parts. A little penetrating oil and adjustment just won't fix worn pot metal. A few years ago a neighbor of mine sold me a few latches and striker plates which I resold. He ran a 56 dump truck until the 90s. He bought out the local Ford dealers remaining stock because he was afraid he wouldn't be able to repair his doors again as the truck became obsolete. Said he had repaired his drivers door striker plate six times and the star wheels numerous times as well. Last well enough for a hobbyist truck but it is a very weak design for longevity.
Hanger53
23
11-06-2016 08:15 AM
bigblockfordman
02-22-2009 11:06 PM
