Door Striker Plate Screw removal
Hey gang, my drivers side striker plate had the bottom teeth broken so the door doesn't stay closed. Before I purchase new ones, is there a special socket used to remove the screws? I've never seen anything quite like this.
Drivers
Passenger
It's probably something super common and I'm just too dense to see it.
Drivers
Passenger
I believe those are called clutch head fasteners. Yours look a little rough which is common. You may need to get a 3/8 drive socket version and use a hand held impact driver. (you strike the driver with a hammer). They make clutch head screwdrivers but I'm not optimistic that will get it done. Get behind them and hit the threads with rust penetrating oil best you can.
Received 4,133 Likes
on
I wonder if that is a plant specific thing? I've never seen clutch head screws like those on Fords, but knew they were common on Chevy's. I agree it's unlikely a simple screwdriver will remove them. Make or buy a proper tool. Those look like someone may have tried to remove them with a flat blade screwdriver.
They look like the screws holding my striker plates on. I just use a big, the biggest I have, standard slotted screw driver.
Do you have a replacement striker plate? I am sure you don't want a chromed repopped one, right. You can find NOS ones on ebay. I have found the NOS ones wear better. The chromed ones stood out on my truck of course and the the two tips wore off faster since my doors are aligned perfectly.
Thanks guys!
Last night I had to go to town to shop for a new washing machine.
Well Lowes didn't have anything. Surprisingly Menards had a couple, but they were way too small.
BJ, I'm sure surprised that Walmart has them.
Abe, Yeah I'm not fond of the idea of the chrome replacements for my truck. It looks like the NOS ones run about the same price as the chrome new ones. 56 ones seem more available on my quick search and I think those are slightly different. Need to check my book.
Yes the 56 striker plates are slightly different. They are thicker to accept a bigger 56 star latch. There is a cover that goes over the plate to keep the doors latched in the event of an accident.
Of course you see more right side than left as the driver's door is used more.
Let me check my stash. If I have more than one part sided striker plate incan send you one. I had more but sold some on eBay. I am keeping a set as back up for me. But if I have an extra I will let you know.
