Sponsored by: Halo Lifts
Max Trailer Tow Package How Much Can I Tow?
Old 11-05-2015, 10:56 AM
j.grif's Avatar
j.grif
j.grif is offline
On my window sticker, it says 7000# gvwr, in door sticker, the allowed weight is 1729#, if my math is correct then, the truck should weigh 5271 plus fuel, correct? This is on a 145 wheelbase supercrew w/ max tow.
Old 11-05-2015, 11:00 AM
Tom's Avatar
Tom
Tom is online now
Yup, your math is correct. My truck is the same configuration as yours, but an XLT with the standard tow package. I'm rated for 1,830 lbs payload.
Old 11-05-2015, 11:02 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Yes, all literature is subject to errors. But, there are some who believe everything they read in official literature. (If any of you are of that persuasion then see me and I'll show you just a few of the many in Ford's 1980-1989 Master Parts Catalog. But, it is still by far the best reference we have on those trucks.)
Old 11-05-2015, 11:17 AM
j.grif's Avatar
j.grif
j.grif is offline
XLT as well, w/sport appearance and twenties, 302a pkg, wonder what the difference is, most of these options are replacing standard parts, just gingerbread.
Old 11-05-2015, 11:27 AM
Tom's Avatar
Tom
Tom is online now
I bet most of the difference is the wheels. Mine's a 301a with the 18" wheels and the 36-gallon tank. I can't imagine the heated seats, MyFordTouch, and power slider weigh that much.
Old 11-05-2015, 11:30 AM
F2502011's Avatar
F2502011
F2502011 is offline
Originally Posted by senix
I think I see where the confusion is...no Ford is not going to print it on the door cert or the manual because to varies too greatly.
Do this.
1. What is the max load at max psi on the rear tires. Take one and double it. That is the max load you can put on the tires.
2. Door cert. What does it say for the max load on the rear axle?
Take the less of the two and that is what you have for payload or tongue wt...by those two figures.
Now go to the scales and get the actual numbers of the drive and steer weights. Do this without the trailer.
Take the combined of that minus the door cert and now you have the actual payload number. That actual payload number is what you can translate into tongue wt.
Next you are going to need to weight the truck and trailer combined to get the empty weight of the trailer.
Keep in mind that when you put both on the scales your truck will be different. But you now know what the truck is empty so the different of that and what the trailer weight can give the true empty wt of the trailer.
Now you should know how much you can put in the trailer, keeping mind the trailer axle ratings and the tires themselves.
Hope that helps.
I think it would be much less of a hassle to assume that my truck weighs between 4940 and 5500 lbs. My trailer weighs 3600 lbs and can haul 6800 lbs additional cargo. It has a 10,400 lb total GVWR. My GCWR is 16,900. Max payload is 2060. Actual payload would be somewhere between 1500 lbs and 2060 lbs depending on the actual weight of the truck. So I think I should be good with my current trailer and possibly a slightly heavier one of up to 11,500 lbs or so.
Old 11-05-2015, 11:40 AM
Tom's Avatar
Tom
Tom is online now
I treat the limits as guidelines. There isn't any specific component that's going to fail if you are a few pounds over your max weight. I pay more attention to axle weight capacities and the tongue weight rating of the hitch than anything else, I believe those are the only numbers that represent actual mechanical limitations.
I've had as much as 16,000 lbs behind my previous F150 and it did a fine job.
Old 11-05-2015, 12:51 PM
Frantz's Avatar
Frantz
Frantz is offline
Limit is just that, the limit. It's a guideline set by Ford as a CYA measure. That means that you weigh 150 LBS and you have a gallon of fuel in the tank and the tongue weight is just right. If you are awful close to the limit on a regular basis then you should consider a bigger truck.
As I said in the very first response though, your limit is 11,500# according to the digital tool Ford gives me to build them. I don't like giving "just because" answers like that, but its all I've got that I can see.
Old 11-05-2015, 01:23 PM
wojowojo16's Avatar
wojowojo16
wojowojo16 is offline
what are the rear gears?
Old 11-05-2015, 02:02 PM
Frantz's Avatar
Frantz
Frantz is offline
3.55 is what comes with max tow
Old 11-06-2015, 10:46 AM
F2502011's Avatar
F2502011
F2502011 is offline
Mine says 1605# so mine would be at 5395.
HRTKD
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
03-09-2019 06:15 PM
PAWZ Guitar Company
2015 - 2020 F150
07-20-2018 10:23 PM
Bigred15
06-08-2017 06:54 AM
wojowojo16
2015 - 2020 F150
12-18-2015 02:08 PM
newtraveler
2009 - 2014 F150
03-05-2013 08:28 PM
Quick Reply: Max Trailer Tow Package How Much Can I Tow?
