installing fiberglass rear fenders by yourself
Old 10-31-2015, 02:31 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is offline
I was wrong..... I'll say it again I was wrong. https://www.ford-trucks.com/forums/1...56-f100-2.html
The kid is like 26 now. I quit keeping track once he was old enough to buy the beer!
He used to be my helper when I needed help like hanging fenders or putting on a hood....... Now he has a girl friend....... there went my help
Old 10-31-2015, 02:41 PM
fatfenders's Avatar
fatfenders
fatfenders is offline
You had me going there. Purple55 did take some heat for his lilac truck though. Your thread is officially hijacked John. And I do hope folks have a good sense of humor here or they'll be running me out of town soon.
Old 10-31-2015, 10:24 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
Originally Posted by 3golfjack
What color of blue are your fenders. Great color, I like.
A customer brought me his 55 for a new bed and some paint work. This was the "original" color. I believe that I have the paint code somewhere for the custom match that TriCities Paint (TCP) mixed. Here is the whole truck, pic taken at the F100 Western Nats a couple of years ago.
Old 12-10-2015, 06:27 PM
jniolon's Avatar
jniolon
jniolon is offline
old and in the way
we now return you to your regularly scheduled thread...
check my measurements and I was within 1/8" of the numbers posted by jvmcc... hung them and backed away and they looked fine... besides you won't be able to see them at the same time.
I was gonna wait for my bodyman/postman to come help but the post office wants about 15 hours a day of his time lately...
bit the bullet, marked and drilled them... will hang tomorrow and see how close I am... I'm using Mid50 bolts 5/16 SS and gonna get some SS fender washers tomorrow... hey !! first time I've used fender washers on actual fenders !!
seems like someone mentioned using blocks around the glass flange... drilled the top hole 3/8" and the bottom is just a backer board to keep it from splintering out too much... used a 'bullet' bit (with a pilot tip) and did the deed..
Old 12-10-2015, 06:37 PM
CharlieLed's Avatar
CharlieLed
I would offer one more tip...when you bolt up the fender, use some epoxy or JB Weld on the backs of the fender washers to hold them firm to the FG fender. Scuff the washer a bit to give it some tooth for the epoxy to bond to. It doesn't take too much vibration to fray FG, the stabilized washers will help to keep that from happening.
Old 12-10-2015, 06:56 PM
fatfenders's Avatar
fatfenders
Looks like progress John. Charlies idea sounds like an easy precautionary measure. That should make them a lot stronger on the flange. I used to have glass front fenders and a few of the holes were showing a little wear when I removed them.
Old 12-10-2015, 07:32 PM
jniolon's Avatar
jniolon
jniolon is offline
old and in the way
Thanks Charlie.... excellent idea... I was just wondering how much the fenders might move around as the body/frame shifts position... JB it is
I could go ahead and mount all the washers and clamp them in place before hand too
j
Old 12-10-2015, 08:49 PM
Steve Bennett's Avatar
Steve Bennett
Steve Bennett is offline
John, I have rear fiberglass fenders on my truck and I also installed the rubber fender welting that has the exposed bead between the fender and box. Set up that way for 3 years and 11,000 miles now and no indication of unusual wear. Good to see the progress!! Steve
Old 12-11-2015, 04:06 PM
jniolon's Avatar
jniolon
jniolon is offline
old and in the way
spent the afternoon drilling the remaining holes and mounting up the fenders temporarily ... to be removed for paint.... it's looking like the back end of a truck more now instead of a pulpwood hauler
and this thing is getting to be a bear to push around... guess it's up over 1500#s by now...and it's just slightly up hill.... my old bones and muscles are straining
later
john
Old 12-11-2015, 05:34 PM
jvmcc's Avatar
jvmcc
jvmcc is offline
I am pretty sure that the color is "Glacier Blue". It was available as a stock color for these trucks. I just painted my own '53 this color. It's got a touch of grey in it. It's not real noticeable, but it's enough take the wussness out of a medium/light blue.
49willard
01-28-2015 10:43 AM
ChuckRob
11-30-2012 09:10 PM
kc 300EX
12-04-2008 06:58 PM
51truck
09-21-2008 09:00 PM
GreatNorthWoods
25
09-21-2006 06:03 AM
Quick Reply: installing fiberglass rear fenders by yourself
