Loud Idle quiets with RPM
Old 10-30-2015, 04:53 PM
1978Crew's Avatar
1978Crew
1978Crew is offline
e99 with 291K on 7.3L
Idle sound horrible. Sounds like a really loud dieseling or I dumped ball bearings in the topside of the engine. When I start to give it a little pedal, the sound drops to normal. No power issue I can tell.
This just started this morning. It happened when cold and then again when hot as well. While driving, and at temp, when I let off the fuel to coast or stopped at a light, the loud idle would cycle on/ off like someone was throwing a switch. When I got home and popped the hood, I could not tell where the sound was coming from.
Any ideas as to the source? or where I should start looking?
Thank you in advance.
Old 10-30-2015, 05:09 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,188 Likes on 816 Posts
Have you done injectors? Reason being is that once splitshots start getting old the cackle becomes more noisier and almost sounds like a rod knock.
Old 10-30-2015, 06:07 PM
1978Crew's Avatar
1978Crew
1978Crew is offline
I have not done injectors. Would they crash so dramatically in one day?
Old 10-30-2015, 06:20 PM
FiznUKa's Avatar
FiznUKa
FiznUKa is offline
Sounds like it is time for the hutch mod if you have not done it yet. Or your fuel pump is not maintaining pressure and is introducing air into the system. If it sounds like a rod knock on the d/s rear that is more than likely what's happening. I get the same knock if I push the go fast pedal to low for to long. Just a thought.
Old 10-30-2015, 08:06 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Do you have a way to monitor ICP pressure, ICP voltage and IPR duty cycle? Have you ever heard a KOER test being run?
Old 11-02-2015, 11:03 AM
1978Crew's Avatar
1978Crew
1978Crew is offline
I do not know what the KOER test is.
Old 11-03-2015, 03:47 AM
Tugly's Avatar
Tugly
Tugly is offline
When I had a banging idle with really warm oil, and it would disappear with throttle - it was a couple of injectors. This happened to my injectors in one day:
Oil way past change time, air in fuel, or improper maintenance schedule on the fuel filter can lead to messes like this. Our injectors are not fussy about what they eat - just how it's dished up. The biggies in diesels are clean air, clean fuel, clean oil... and plenty of 'em.
MKEBoost
EcoBoost (all engine sizes)
15
11-29-2015 09:06 PM
MisterRanger
1983 - 2012 Ranger & B-Series
20
06-04-2012 06:52 PM
wreckinball
12-23-2010 11:40 PM
basstardo
11-09-2003 08:45 PM
79CEEJAY
29
09-05-2002 11:02 AM
Quick Reply: Loud Idle quiets with RPM
