pleASE HELP.check engine light kills trk.
Old 10-29-2015, 11:04 AM
rbeesley's Avatar
rbeesley
rbeesley is offline
1993 5.0 f-150 automatic
engine idleing really rough then check engine light comes on and idle smooths out.
when the check engine light is not on the trk goes into gear and shifts smoothly as it should but once the check engine light comes on it SLAMS into gear and shifts really hard.
please help as i drive this truck to and from work every day.
the check engine light comes on about every 3-4 minutes and the goes outat which time the engine tries to stall out completely
Old 10-29-2015, 03:50 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
1st thing is you need to see what codes are displayed on the vehicle computer......if you don't have a scanner, AAMCO, autozone, etc will pull the codes for free, then you will at least have an initial concept of what the issue(s) could be.
Old 10-29-2015, 03:56 PM
Kevin Kanzler's Avatar
Kevin Kanzler
Kevin Kanzler is offline
I agree with beechkid. It is an ECC-IV instead of OBD2 connector as well. (Obd2 has made it so easy)
Shark2323
6.4L Power Stroke Diesel
07-16-2019 09:25 AM
chrisginco
04-25-2013 04:36 AM
wrdabney
24
08-26-2012 04:03 PM
Carnivore
2004 - 2008 F150
02-04-2010 07:55 PM
alopez2
11-29-2004 06:54 PM
Quick Reply: pleASE HELP.check engine light kills trk.
