That T sends warm/hot coolant dwn to the bottom of rad to warm up your trans oil cooler in the bottom of rad before every thing gets up to the operating temp
The small hose that comes off of the heater hose should go dwn to bottom pass side of the rad and connect to a fitting there. the inside of that fitting is a small office hole. There is no return hose coming back up.
