94 single belt system on a 91 triple belt?
Old 10-03-2015, 02:42 AM
bluemtn95ford's Avatar
bluemtn95ford
bluemtn95ford is offline
Okay, so I've been on here before diagnosing problems with my 94 7.3 idi. Long story short it threw a rod and needs rebuilding, or the route I decided to go, a drop in motor. I bought a 7.3 out of a 91 250. 180000 miles. No turbo. I plan on replacing all gaskets, putting the turbo from my 94 on, and eventually dropping it in. The question I have is this: The 91 Idi was set up with a three belt pulley system, my 94 had a single belt system, much easier to mess with. Is it possible to switch over pulleys and/or alternator/water pump, and whatever else from my 94 onto the 91? I think the water pump is interchangeable, the alternator doesn't appear to be, and I'm not sure about pulleys. Any info is appreciated.
I'll also be posting this in the IDI section.
bluemtn95ford
10-04-2015 09:25 PM
onsiteford
03-23-2012 10:48 PM
MONAVIERONJON
07-29-2009 09:01 AM
jd730d
02-14-2007 09:35 AM
Quick Reply: 94 single belt system on a 91 triple belt?
