Gear oil
Old 10-01-2015, 11:57 AM
hotrodjohn71's Avatar
hotrodjohn71
hotrodjohn71 is offline
Gear oil
I have a 1956 F250 3/4 ton truck running gear (with a 58 cab and bed)
which weight of transmission and rear diff gear oil and which brand are you using?
Old 10-01-2015, 02:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Bookmark this page: http://www.clubfte.com/users/earl/Re..._Material.html
lots of good stuff on there.
There is a lube chart on there that says SAE 90 for normal temps. The key is it needs to be GL-4 spec, and as far as I know, only StaLube sells that, thru NAPA and some farm supply stores.
There are GL-5 85w140's available everywhere that claim to be "copper-safe", in particular Valvoline High Performance 80w90. Even Walmart's 85w140 claims to be safe. I believe them to be, but if you don't want to take a chance....
Old 10-01-2015, 10:06 PM
Brian~50F3's Avatar
Brian~50F3
Brian~50F3 is offline
Old 10-02-2015, 11:29 AM
hotrodjohn71
Great advice! Thank you!
So GL-4 for both the diff and trans?
Old 10-02-2015, 12:11 PM
hiball3985's Avatar
hiball3985
hiball3985 is offline
GL4 for the trans, it has soft metal brass syncros. I've used GL5 in the rear ends with no problem.
I also get GL4 from Amazon..
wagonerkl
11-25-2010 11:31 AM
MThrasher16
05-09-2010 02:51 PM
MTurner2003
18
10-27-2005 09:07 PM
ukfanalways
Oil & Lubrication
12-19-2004 07:03 PM
Quick Reply: Gear oil
