Quick, dumb question
Yeah, I tried google and get a lot of stuff on replacing the flasher on the fuse cluster, but nothing on the actual button itself. I figured it might be on top of the column....the junk yard has about 20 trucks and they are all either tilt-column or the column has been removed, so I have no source for parts at the moment. I'm still working on getting the column cover.
http://image.mustangmonthly.com/f/te...mn_diagram.jpg
Mustang column....I seem to remember a small notch in the same area on mine as where the mustang flasher button is. I'll check it out when I get home tonight.
Received 3,108 Likes
on
That's some good info to have. There are a bunch of tilt columns at the junk yard, no straight columns. Might pick up a spare for if/when my bearing goes out.
On a side note, I went to pull the steering wheel last night, like I've done many times before, and the cheap bolt that came with the tool I rented snapped flush in the hole in my steering wheel. No way to pull it now without extracting the screw....
rpminihan
20
08-23-2016 04:22 PM
MontanaFord
05-05-2004 11:58 PM
