Lower trailing arms bolt size HELP
It's time for me to change the lower trailing arms on the back of my 2001 Expedition. I know one of the bolts would have to be cut in order for it to come out but I would like to go ahead and buy the bolt ahead of time to have it ready to be installed. I got the trailing arms from NAPA and they didn't come with any hardware. On one of the other forums I saw that the size might be 5/8"-18 3.5 inches long but would like to confirm before I buy it.
Thank you
Thank you
This is exact the bolt you need:
https://www.boltdepot.com/Product-De...x?product=6803
The nut if you want a new one:
https://www.boltdepot.com/Product-De...x?product=6888
If you prefer a flange nut:
https://www.boltdepot.com/Product-De...?product=17700
Thank you for your help
Got the lower trailing arms replaced along with the track bar. It did take a while to align the holes on the passenger side for the trailing arm. And I did end up cutting the bolt in half to get it out.
Now I should probably replace the upper ones as well. Are they just as hard to replace?
