i put a new master clutch cylinder on my 93' f150 and am thinking of bypassing the clutch safety switch because it doesnt fit very well on the master cylinder clutch pedal rod..... how could i bypass it or should i just prop it open with a screw.... any thoughts??????
If it's anything like what was on mine there's about 4 or 6 wires going to that switch. The power circuit for the starter solenoid plus signal circuits for other crap like speed control servo.
What I did on my Ranger when the clutch switch burned up was just jump the two heavier wires together which bypassed the switch.
The two red with blue are starter the next two are cruise control I've had mine jumpered for most of a year and have no idea what the last two do so they're provably not that important
sweet y'all thanks!!! i just been opening the switch with a screwdriver lol which it works but it getting kind of annoying.... and what do you mean by "the JY"???
one other question for you guys... i changed my sparkplugs and i think a leaf or some crap got in the cylinder.. would that cause the engine to shake at an idle???? because it runs fine but it does kind of shake when the rpm's are low or its idling.... i also changed the fuel filter so i dont think its the fuel.... could it be the fuel pump????
