tool answer
Old 09-16-2015, 07:39 PM
Leroy Axe's Avatar
Leroy Axe
Leroy Axe is offline
tool answer
Looking to buy a valve spring tool for the 5.4.
OTC has 2 part numbers for a tool that works on the 5.4, or so I assume anyway.
OTC number 6684
OTC 303-1039
Whats the difference?
I want to buy one ,or the other.
Old 09-16-2015, 07:49 PM
Ted928's Avatar
Ted928
Ted928 is offline
According to OTC 6684 Ford 3V Valve Spring Compressor Like 303-1039 | Hard to Find Automotive Specialty Tools
the only difference is cost.
"OTC 6684 is just like the Rotunda 303-1039 both made by SPX but the OTC6684 is sold at a much lower cost. Ford valve spring compressor for Ford 3 Valve engines. Also see the OTC-6681 (303-1175 equivelant) that is often used in conjunction with the 303-1039."
Old 09-16-2015, 08:00 PM
Ted928's Avatar
Ted928
Ted928 is offline
This tool is cheaper and looks more solid to me.
I have not used any of these tools.
Old 09-16-2015, 08:11 PM
Leroy Axe's Avatar
Leroy Axe
Thank you Ted.
This tool is for the 2 valve engine
I was looking at the other 2 tool numbers and did not see a difference.
I wondered if there was a hidden difference, like tool quality, or fit and function.
Have you used either tool? Thanks
Old 09-16-2015, 08:28 PM
Ted928's Avatar
Ted928
Ted928 is offline
Originally Posted by Leroy Axe
Thank you Ted.
My bad - I didn't realize that there was a 2 valve 5.4.
No I haven't. There is a recent thread which shows the tool broke. I don't recall which tool it was.
I just don't understand why it takes such an expensive tool to simply take the load off the spring. I wonder if a universal tool would work.
Old 09-16-2015, 08:39 PM
Ted928's Avatar
Ted928
Ted928 is offline
This guy modified the 2V tool to work on the 3V engine.
Cheap 3V 5.4L timing/valve tools (pics inside) - F150online Forums
Leroy Axe's Avatar
Leroy Axe
I saw the thread with the broken tool.Part of the reason for this thread.
I don't want to buy an inferior tool.
If the only difference is the price then well........
Old 09-17-2015, 07:43 PM
Leroy Axe's Avatar
Leroy Axe
Thanks Ted. I did not see the thread with the inexpensive tool/mod so it was pretty cool to see. Great Pics also.
Thanks to the OP (of that thread).
Bensony
05-25-2019 03:49 PM
DutchmanAZ
Garage & Workshop
09-10-2014 06:17 AM
theGman
64
12-28-2007 09:02 PM
Quick Reply: tool answer
