1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Does my truck sit lower then stock?
Old 09-15-2015, 10:22 PM
67highboy's Avatar
67highboy
67highboy is offline
Since I got my truck on the road I feel like it sits too low for a one ton, 4x4, crew cab, long box. Am I right?
Old 09-15-2015, 10:28 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
What year is it? Measure from wheel hub center to top of fender and compare with others.
Old 09-15-2015, 10:49 PM
NYCruiser's Avatar
NYCruiser
NYCruiser is offline
Doesn't look low to me. Might just be an optical illusion because its so long. A tape measure wouldn't lie though.
Old 09-16-2015, 05:41 AM
Good listener's Avatar
Good listener
Good listener is offline
Looks like mine. Long Beds look lower for some reason. Super Dutys are lower than other brands and fit 5th wheels better.
Old 09-17-2015, 05:08 PM
67highboy's Avatar
67highboy
Center cap to bottom of the fender is 23.5". There is no block between the rear axle and leafs. Is that normal?
Old 09-17-2015, 05:22 PM
Omega Man's Avatar
Omega Man
Omega Man is offline
Someone leveled the truck by removing the lift block in the rear. I did the same thing, I think it looks stellar.
Old 09-17-2015, 05:57 PM
Bently_Coop
Take a picture of the rear suspension showing the springs. You can always add the blocks if you want to. Below is a link for part numbers of F350 blocks, keep in mind they are different based on wheel base.
https://www.ford-trucks.com/forums/6...ar-blocks.html
Electricowboy
03-29-2021 06:48 AM
56panelford
33
11-25-2014 08:34 PM
fx4maddawg
2004 - 2008 F150
09-05-2013 10:41 AM
hoof
17
06-23-2007 05:30 AM
Snowking
08-12-2006 06:21 PM
Quick Reply: Does my truck sit lower then stock?
