Question about rear axle.
on
looks like someone swapped in a different centre section into the original housing. probably wanted to get a lower gear ratio then the original ratios the truck came with. looks like a centre section from a car as it has the snubber thing on it. never seen a truck come with that.
rgds
mike
rgds
mike
The quick and dirty way is to turn both wheels at the same time in one full rotation, and count the number of times the pinion turns. For instance one full turn of the the wheels yields roughly 3-3/4 turn of the pinion, the ratio is probably 3.73:1.
The more accurate way is to open it up and count the teeth - ring gear divided by pinion equals the ratio.
8086ford
02-17-2016 12:13 PM
Alcaeus
09-24-2010 06:20 PM
Dirt Head
01-15-2005 12:38 AM
rig_pig30
08-30-2004 12:20 AM
