Gas Cap Woosh...
on
Gas Cap Woosh...
I just noticed my gas cap seems to ""Woosh" when I open it: I am not sure if it is a pressure or vacuum woosh: I do know I could smell fuel quickly after I opened it this AM... Is the cap supposed to be vented, and what symptoms would indicate blockage if so?
Thanks!
Scott
Thanks!
Scott
on
It seems to be the woosh is outbound- like the tank is pressurizing: something it has not done before... Enough so you can smell gas, and the threads of the gas cap are wet... I wonder if it may be, as suggested, a plugged charcoal canister or line thereto... Could it be something in the selector valving?(Twin tanks)
Scott
Scott
on
Assuming this issue is on your 1991 F150 in your sig then you do not have a selector valve. The vents are tied together then routed to the charcoal canister. The Canister Purge (CANP) solenoid is activated by the computer to allow the fumes to be drawn into the intake plenum.
Some reading from the Ford Service Manual to cure insomnia:
Fuel Evaporative Emission System
The evaporative emission system limits the amount of fuel vapor a vehicle may release to the atmosphere, enabling the vehicle to meet current federal and state requirements for fuel evaporation. The system works by capturing a very high percentage of fuel vapors that might otherwise escape from the gas tank. It then directs these vapors to the carbon canister where they are stored while the engine is not running. When the engine is running, and conditions are acceptable, the vapors are purged out of the canister and into the engine. This "clears" the canister and allows it to accept more fuel vapors the next time the engine is shut off.
The system is basically the same for all vehicle and engine lines: a hose or tube runs from the top of the fuel tank to the carbon canister to allow fuel vapors to pass from the tank to the carbon canister. A tube or hose runs from the carbon canister to the engine, allowing vapors to be purged from the canister. Some engines use additional valves in one or more of these lines to provide additional control over how much or when fuel vapor will be allowed to pass.
Sportsterengr
04-18-2016 02:29 PM
myklstrng
11-01-2010 11:06 AM
