76 4x4 questions
76 4x4 questions
so I recently acquired a "project" As I need to replace the long tie rod anyway I'm trying to find some info on upgrading. I read some where that I can use a later model tie rod/drag link set up and do away with the funky "y" original to the truck. What year should i look for ? Also I have 2 tanks. Which is the main? Behind the seat or under the rear? Thanks for yer time!! Oh yea. It's a F100 short box if that makes any difference.
The rear tank should be the main, and also the default tank if you ever loose power to the switching valve. I always used the aux. first in case there was a problem. I've seen plenty of drivers over the years go to switch from main to aux. only to find they couldn't due to some failure in the valve or electrical.
TheRedlines
01-27-2017 08:07 PM
Golden210
10-23-2014 09:37 PM
crazy96863
12-31-2011 03:12 PM
