1994 turbo idi white smoke
Old 08-19-2015, 09:40 PM
1948mm's Avatar
1948mm
1948mm is offline
I just picked up a 1994 turbo idi with 260000 miles on it. It starts good but runs rough and has lots of white smoke. Runs better after warmed up but still not right. I am plannimg on doing a tune up. I will have the injectors checked but was wondering if the tappets were hydraulic or solid and adjustable? Thanks
Old 08-19-2015, 09:44 PM
Macrobb's Avatar
Macrobb
Macrobb is offline
Lifters are hydraulic roller lifters.
Your problem is most likely timing. Advance the pump a few degrees and see if it helps. IP and injectors are probably worn(out) by this time.
Old 08-20-2015, 12:50 AM
Runningaford's Avatar
Runningaford
Runningaford is offline
We had an old 84' van that after rebuilding blew white smoke; we thought it was timing, but turned out to be a water.
When we rebuilt the engine, we didn't have the money to get the block checked, and it turned out that it had several cracks; we checked carefully but didn't see them.
All in all, we were able to run it for 30k miles before it really grenaded.
Old 08-20-2015, 08:13 AM
1948mm's Avatar
1948mm
1948mm is offline
Does this fuel system use a return check valve that I could check and see if its plugged?
CanMoose
03-26-2017 10:14 PM
89IHDiesel
08-26-2014 04:46 PM
darkpurp1e
10-24-2013 04:50 PM
442john
07-03-2007 09:35 AM
derekj4
10-08-2003 08:29 PM
Quick Reply: 1994 turbo idi white smoke
