650cfm on 302
Old 08-17-2015, 07:26 PM
balboni's Avatar
balboni
balboni is offline
650cfm on 302
Is the fuel.pumps the.same on a 79' 302 and a 87' 351w and if not could the pump from the 302 support my 650cfm on my 351w
Old 08-17-2015, 07:34 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Compare PNs.
Probably... unless you're' turning more than 6000 rpm.
Old 08-23-2015, 01:56 PM
bkaul's Avatar
bkaul
bkaul is offline
Mechanical fuel pumps between 302 and 351W are interchangeable ... like HIO says, there may be different applications that have different flow rates. (E.g., the mid-80s Mustang 302s w/ 4V carb might flow more fuel than the '79 2V application). But that probably won't be an issue unless you're drag racing the thing.
However, an '87 351W was presumably fuel-injected? That would have had an electric in-tank pump. You may need to replace the timing cover with one that supports a mechanical fuel pump if the engine wasn't originally equipped with one.
Old 08-23-2015, 05:38 PM
DeereFord300's Avatar
DeereFord300
DeereFord300 is offline
The '87 351 and 460 were both carbed still, it was the 1st yr of EFI for the 300
Old 08-26-2015, 08:38 AM
bkaul's Avatar
bkaul
bkaul is offline
Ah, good to know - I was thinking they had switched the 351W to EFI the same year as the 302 ('86). Guess I was wrong.
Turxx
01-09-2013 12:48 PM
rattosh51
13
08-07-2007 09:59 AM
N-videto
05-30-2004 09:38 AM
droach4u
04-27-2004 11:38 AM
screwy
1978 - 1996 Big Bronco
01-14-2003 07:57 PM
Quick Reply: 650cfm on 302
