Converting To Disc Brakes
I have obtained the front suspension from a 1978 Ford Truck which I will use on my 1965 F100 restoration. My question is; Can I use the Radius Arms off the 1965 with the I-Beams and disc brakes from the 1978 Ford Truck? The 1965 Radius Arms are in better shape and look to be better made.
NEXT QUESTION: The I-Beams from the 1965 Ford F100 have a Metal Bar attached to them that hooks onto the truck frame (don't bolt on, just hooks onto the frame). The 1978 front suspension does not have these "hooks" attached to the I-Beams (and no way, that I can see, to attach them) am I going to be OK or have I messed up?
Hopefully someone can help me.
As for the "metal bar", I'm not sure what you're referring to....my '66 didn't have one to my knowledge and therefore I certainly don't miss it. LOL! I used '78 suspension in my disc brake conversion, too. Good luck with it. It's a fairly simple upgrade.
Where in OK are you? I'm originally from there and headed there for a visit next week.
Randy
Frame with rear end & springs
LOL
No, that's some used carpet that I came across. Makes for a nice area to work on instead of cold cement.
I uploaded a photo of the frame and rear end and leaf springs. Frame has POR15 w/ a top coat on it. Rear end and leaf springs have been powder coated. Working on getting the front end fixed up now. That's why I'm asking my questions.
I have a '69 F100 that I converted from manual 4-wheel drums to '77 F100 front discs/I-beams/radius arms. I also switched my truck from manual steering to power steering and from manual brakes to power brakes.
My front suspension before.
After. (also note the flexible caliper hose to hard line frame bracket was changed to the frame brackets from the '77 F100).
Difference in brake hose-to-hard line frame bracket. (photo in following link courtesy of HIO Silver).
http://i42.tinypic.com/vnjhgj.jpg
My brake booster is a factory Bendix dual diaphragm unit from a '75 F350. The input rod of the booster was a direct connection to my '69 brake pedal, with no changes or modifications.
My power steering gear box is a Saginaw unit from a '78 F150.
The Saginaw PS gear box will require a shorter length steering column, a shorter column bracket on the engine side of the firewall and the seal at the base of of the column tube inside the cab. I installed a tilt column from a '78 F150. --automatic transmission NSS is mounted on column on '77-earlier trucks. '78-up NSS is mounted on the side of the transmission.
My stock '69 fixed column firewall seal on left, '78 PS tilt column seal on right.
Manual steering or Bendix PS firewall bracket on left. PS column firewall bracket for Saginaw steering column on right.
My Ford C-2 power steering pump/brackets came off of 300 inline six that was in an '82 Ford F150.
Front sway bar from a '78 Ford F250 Camper Special.
Ultraranger;
Great, Great, Great photos, thank you very much. This is good info that will help me tremendously. I think I can quit worrying about the "metal bar" or "appendage" as you called it and go with the '78 suspension. Please keep checking for my name as I am sure I will have more questions. Your frame and suspension look real nice. What did you use on them; powder coating or POR 15 or something else? Excellent job on everything in the photos. You've motivated me, which help, believe me!
Ultraranger;
I have only spot painted the frame (only clean and rattle can painted in the front area where I was installing the front suspension). The paint is Dupli-Color Ford Semi Gloss Black DE 1635.
All suspension, engine brackets, etc. that are black were painted with that specific paint.
The frame/body won't get 'properly' cleaned and painted until some time later.
I swapped out the front drums for discs back in October of last year, along with numerous other changes I made to my '69 F100 short bed Ranger. If you're interested, you can read about the details of it at the following link.
https://www.ford-trucks.com/forums/1...ont-drums.html
The appendage just keeps the I-beam from dropping to low and letting the spring come out. It was used in '65 only. 1966 and up use a retainer on the coil spring which is held in by two bolts on top of the spring tower. You can eliminate them or if you want to keep them you can use later spindles on your existing I-beams.
jyro
01-13-2008 05:52 PM
western star
05-08-2006 02:34 PM
