66 f100 king pins replacement
To do this job correctly, you should be able to ream the bushings to match the king pins. If you don't have the proper tools, they are not cheap...... I would suggest you contact a big truck (dumptrucks, etc.) shop that does front end alignments and repairs king pins and ask them to quote you a price. It may be more job than you are wanting to bite off........
Back in the 80s, I tore my '65 apart, installed the nylon busings, new king pins and locking bolt, etc. It wasn't a month later and the nylon was pushing out around the ends of the king pin. I then took the truck to a shop that installed metal bushings and they reamed them to fit. They told me to grease the top & bottom king pin cap zerk every two months. I have and they are still nice and tight and work fine yet to this day.
Barnietrk
Barnietrk
http://www.ford-trucks.com/forums/1392837-66-f100-king-pins-replacement.html
Barnietrk
Barnietrk
Pa's64f100
05-01-2006 08:35 AM
mjunk1
13
11-05-2005 11:12 PM
3904bbl
02-26-2003 01:27 AM
