King Pins
Old Aug 4, 2001 | 08:49 PM
sweetpea's Avatar
sweetpea
King Pins
70 F250 with king pins. Are these along with the rubber bushings on the front end something that a shade tree mechanic can do or is this best left to a pro? If it's something I can tackle, any special tools needed?
Thanks!
Old Aug 4, 2001 | 08:53 PM
PRIMER_78's Avatar
PRIMER_78
King Pins
I bitched out on doing mine adn took it to a pro, ya gotta heat it up wiht a torch to get'em out....
Old Aug 6, 2001 | 01:03 AM
Southwest's Avatar
Southwest
King Pins
You could do it yourself and if you have the pressed in brass bushings then you can take the spindle into a machine shop and have them put in the new king pin bushing and then put the stuff back together yourself and save money. I forget what years but some point they were putting in nylon bushings which are much easier to change but were out quicker.
Old Aug 6, 2001 | 03:15 PM
buzzard's Avatar
buzzard
King Pins
If you can get the original king pins out, it's not a hard job. More than likely, you'll need a big hammer and torch OR a shop press. The rubber bushings are all fairly easy to remove and reinstall.
Old Aug 6, 2001 | 04:48 PM
tetraruby's Avatar
tetraruby
King Pins
[font size="1" color="#FF0000"]LAST EDITED ON 06-Aug-01 AT 06:46 PM (EST) by StockMan (moderator)[/font][p][font size="1" color="#FF0000"]"Link added for convenience"[/font]
There are a few posts from a few months ago about king pins. I did mine in the beginning of june. There's a post [link:www.ford-trucks.com/dcforum/61_79/6398.html|"Emergency King pin question"]. There's some helpful information and some mis-information too. If your truck's spindles are like those on my '79 2WD, expect to spend some time on them. Find a good shop that can press out the old spindle bushings and press/hone the new ones. Go with the metal ones, don't use the urethane ones. It can be an easy project and it can be a real PAIN. I recommend pulling the entire spindle and I-beam and having a good auto machine shop do the pins for you. If you pull the I-beam you can do the spings and pivot bushings too. But, like with all my little projects they turn out huge and take longer and as always -costs more than I expect.
Old Aug 6, 2001 | 08:24 PM
yoda777's Avatar
yoda777
King Pins
