Mounting of a Dahl 100 on an Excursion
Has anyone mounted a Dahl 100 pre-pump on a 7.3L Excursion? I am looking for a spot that gives the most clearance to ground. Right now it looks like there is a frame cross member just forward of the rear axle out of the way of axle travel. Still at 12.5" it will hang down.
I chose the Dahl 100 because I have used one before on an Isuzu NPR... it worked like a charm on that one as the factory Isuzu water separator was ($$$) and you could not actually SEE into the thing. I have to admit that I was tempted to use a spin on rated for suction that would give a lower profile and be out of harm's way. I'm accustomed to setups like the Dahl on farm equipment. Pele, the location I am eyeing is shown in the pic. I want to get the top of the unit as close up to the underside of the body as possible yet be able to drop it down temporarily if need be... and out of the way of axle travel, of course.
Proposed filter location.
I helped installed one on a 2007 F350 and 3 months after installing it, the pump died and left my friend on the side of the road. I'd heard this was an issue with the early pumps, but thought they'd cleaned up their act by now.
Glad to hear things are going good with your Airdog on the Dodge.
I need at least 100 GPH, preferably close to 200. And I need no more than 20 PSI.
I also need a 4 micron or finer filter.
The Bosch VP44 fuel injection pump is cooled and lubricated by the Diesel flowing through it. Most of the fuel going to it is returned to the tank. Thing is, the injection pump will continue drawing fuel even if the transfer pump in the tank fails... It just won't have cooling or lubrication and will seize up about 500 miles later. Ask me how I know...
Too much pressure and too little flow.
I say "ask me how I know" a lot too. People usually don't question me when I do...
I did some reading on the Cummins and know that to be true. The same actually applies to the 6.0, but the pump has to fail while the truck is running. It'll run like crap, but it'll run...you probably won't go too far too fast either. This is why a fuel pressure gauge is your best friend on a 6.0.
I bought my Dodge and the previous owner had a slide-in camper and then a 5th wheel. There was some dodgy wiring under the hood. (Pardon the pun) and I figured it was from some stuff the previous owner put in.
As an electronics technician, I HATE loose wires. (I'll go through a bag of zip ties on a stereo install.) I HATE wires twisted together and wrapped up in tape. (Solder, or at least crimp splices with weatherproof shrink tube on it.) So I ripped it out. Anything wired like that shouldn't be critical.
Towed my wife's car on a U-Haul trailer (Bought my truck in Jersey off of eBay, I live south of Washington DC.) Then I drove it to and from work for two weeks before the truck died on the side of the road.
Apparently, the wiring I pulled out was DEALER INSTALLED. Cummins supplies a Carter pump on the side of the engine block. Chrysler issued a TSB to replace that with an in-tank pump. The wiring was to feed that pump. Any dealer technician that twists wires together and wraps them in tape should be fired and be ashamed of themselves.
The VP44 is a hybrid pump. It's a rotary style mechanical pump with electronic controls for fuel and timing.
Because of the lack of fuel flow, the rotor part of the "distributor" that feeds fuel to the cylinders seized up.
I dropped two grand on a new VP44, an AirDog II 165 GPH pump (Tank sump/draw straw mod included), and a full set of Isspro gauges. (Fuel pressure, Boost, EGT, and Trans Temp)
Pele
05-01-2015 08:13 PM
John7894
08-06-2010 11:26 AM
Vampiro
12-07-2002 01:50 AM
HiMe
12-01-2002 09:19 PM
