Brake issue in Ex
Old Aug 11, 2015 | 10:20 AM
X-ford's Avatar
X-ford
Brake issue in Ex
So I just bought a 2004 Ex 4x4 4wd with only 50k from a dealer. While test driving the truck would shake/shudder when braking at 50-70 getting worse if you were going faster, as a condition of the sale they said they would look into it. They did and said it was the tires?? They balanced and rotated and did and alignment. Are they correct? the tires are BFG AT 33x12.5x16.5 on aftermarket rims.
Old Aug 11, 2015 | 11:09 AM
1NiceHarley's Avatar
1NiceHarley
Sounds like warped rotors.
Old Aug 11, 2015 | 11:25 AM
X-ford's Avatar
X-ford
That's what I was thinking but they said the brakes were fine
Old Aug 11, 2015 | 01:23 PM
RobRoss's Avatar
RobRoss
When you are braking and the truck shudders, do you feel it in the brake pedal? If so, it's the front, if not, rears. I just went through this on my truck and found my rear rotors severely worn. I also had the right rear parking brake partially stuck on. Another telltale sign of rear brake issues is that braking feels smooth when the entire system is cool, the rears take longer to heat up since they don't do as much work as the fronts...then the shudder returns.
If it was tires, it would shake all the time and not just when the brakes were applied. Does or did it shake all the time?
Old Aug 11, 2015 | 01:26 PM
Magnus E's Avatar
Magnus E
Don't forget to check the calipers, they can stick. Do you smell a funny burnt odor from any of the four corners?
Old Aug 11, 2015 | 01:49 PM
X-ford's Avatar
X-ford
No burning smell.it doesn't shake when driving just when brakes applied at high speed. If it is the brakes then they are lying.. They are a pretty big dealership so I don't see how it would be in their interest to lie?
Old Aug 11, 2015 | 01:50 PM
X-ford's Avatar
X-ford
No I don't feel it in the brake pedal
Old Aug 11, 2015 | 05:19 PM
az_r2d1's Avatar
az_r2d1
Most likely brake rotors warped/deposits on it.
Another issue they have is sticking calipers caused by the slide pins not maintained enough. Easy removal and install. But if the calipers stick, this will heat things up a lot and more prone to warped/deposited rotors.
Tell them to fix the brakes and lube the slide pins too once you get back from that first test drive after they do the tires and it's still not fixed.
Old Aug 12, 2015 | 02:20 PM
jpr38057's Avatar
jpr38057
Does it do it all the time? If yes, look at the brake components. My ex is also an 04 and I have been trying to figure out what my intermittent shudder when applying the brakes is. Mine can do it at any speed but is not consistent. About the only thing I have not replaced is calipers.
Old Aug 13, 2015 | 06:52 PM
fordboy67's Avatar
fordboy67
Sounds like the rotors, and I'm a little confused at the tire/wheel combo, are you sure its a 16.5, not a 16? I have never seen a 16.5 on an X.
Old Aug 13, 2015 | 06:54 PM
X-ford's Avatar
X-ford
Yes it is 16.5 they don't sell them anymore.
Old Aug 13, 2015 | 11:11 PM
wpnaes's Avatar
wpnaes
Agree: New rotors/ pads / flushed lines / lubed slides and you'll be out of the braking shudders.
PanamEric
Feb 24, 2017 05:04 PM
'78F250351m
2009 - 2014 F150
42
Sep 5, 2016 06:11 PM
fyrrsqnet
Oct 23, 2007 08:13 AM
TakeEm
Nov 7, 2005 09:41 PM
JLD
22
Jun 22, 2001 06:45 PM
