OBS 2wd 30 to 45 mph curve front end wobble
Have a problem with my 97 crew cab power stroke 2wd.
At speeds between 30 and 45 mph when going around a curve the truck will start having a front end wobble have had tires checked (good no problems) new shocks new steering box & pump new tie rods & ends alignment checked perfect caster/camber also checked perfect ball joints are new.I have done everything that I can think of to fix this problem. Have jacked up the front end and grabbed the wheels and have found nothing loose or wobble on either side.
VERY PUZZLED AS TO CAUSE??? ANY HELP????
midsouth
08-09-2015 04:24 PM
