Front end shake
Old Sep 6, 2010 | 09:46 PM
Cobra Highboy's Avatar
Cobra Highboy
Front end shake
hey all,
I was driving my truck this weekend doing 70 mph.
I was going around a curve and hit a bump with the left front tire and the front end started shaking violently. It was all I could do to get the thing stopped without crashing. Has anyone had this happen and what could be the cause? My truck is a 96 F-250 PSD with one ton axles (Straight axle front D-60) This also happened once when I still had the TTB front end.
Any help is appreciated Thanks in advance.
Old Sep 6, 2010 | 10:21 PM
jplinville's Avatar
jplinville
Bent rim, loose tie rod ends, tire with a bad belt...the list goes on.
Old Sep 6, 2010 | 10:22 PM
redlightning93's Avatar
redlightning93
Do a search for "death wobble". There are many posts on this problem. Good Luck
Old Sep 7, 2010 | 05:28 PM
Chester_field's Avatar
Chester_field
Mines done it on few occasions started doing it again just resently. It is mostly bad shocks they have 1/2 million Km's on them, when I back up the tires lean-in really bad going forward there straight. Ball joints are new Tie rods,(inner and outer are new) the steering box isn't that old either. I just hang on slow down until I get time to fix it. Oh ya I have new wheel bearing yet to go in too.
Rotate your tires see if it goes away, check your shocks, ball joints, tie rods. Good luck cause it will never go away forever.
Old Sep 7, 2010 | 09:39 PM
jplinville's Avatar
jplinville
Common on TTB
Old Sep 8, 2010 | 08:55 PM
Chester_field
I read the Death wobble posts its more like a death hop the tires leave the road or at least 99% sure they leave the road
crrnchris
34
Oct 9, 2012 06:02 PM
sjgordo
Dec 10, 2009 04:22 AM
Black88GT
Oct 1, 2004 04:27 PM
boroarke
Jul 19, 2003 08:32 AM
