1986 F350 T18 Trans Issue.
Hey guys,
I'm new to the forum so if I'm doing something incorrectly, sage advice is appreciated. I've got an '86 F350 (T18 Borg Warner) that has a bad transmission shimmy in 1st and reverse gears. The problem is slowly beggining to encroach into 2nd gear. Note, this is only while I am engaging the clutch from a dead standstill. Once the clutch is fully engaged, the shake goes away. The problem has just recently occured. The truck has been in the family for a long time so I am familiar with the service history and I have owned it for several years. Thoughts and theories?
Thanks,
Bo
Thanks,
Bo
Ok. Thanks for the tip. I know that my uncle replaced the clutch less than 15k miles ago, so I doubt it would be that. Is there a way to check for a bad rear seal without dropping the trans? I keep an eye on the oil constantly, giving its old nature and that its a diesel, and I have not noticed any drop in oil lately.
Bummer on the lack of an inspection cover. Without that, you really have to at least slide the transmission back to inspect the clutch.
All - Do you agree that it sounds like a clutch problem? Could it be that his style of driving has glazed the clutch? And, did the diesels w/a T19 have a dual-mass flywheel?
Thanks, Dave. I didn't want him pulling the tranny on my suggestion alone.
If the clutch was replaced 15k miles ago then I wouldn't expect it to be worn out. That leaves, as Dave said, some contamination on the clutch, like oil or coolant, or glazing from improper use. In either case you may be able to, at least temporarily, fix that by serious slippage. I've known people who pulled up against a tree and then rev'd the engine enough to not stall and slowly released the clutch to the friction point. A few seconds of that can some times remove a glaze. But too much can warp the flywheel. And if the clutch disk is completely worn out it can ruin the flywheel.
Bo - It is your call on whether to do that or not. I would if I knew the clutch had plenty of lining.
ejcheli
36
08-05-2020 06:54 AM
first time 4x4
02-09-2003 09:41 PM
