2003 standard transmission issues - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 01-16-2018, 11:19 AM
Ben Samways's Avatar
Ben Samways Ben Samways is offline
Ben Samways is starting off with a positive reputation.
2003 Escape 2WD 2.0 4-cyl with 5-speed manual. About 96,000 on the odometer.
Last Wednesday, I was waiting at lights for a train to pass, so was in neutral. When the barrier lifted, I tried to get into first, and nothing. Pumped the clutch multiple times and still couldn't get into gear. I tried all five forward gears and reverse, no luck.
Got a tow from AAA to our mechanic who looked into it over the next couple of days - no leaks from clutch master or slave cylinder. Took a lot of pumps of the clutch pedal to enable them to get it into first to drive it into the bay. They checked it over and found that the transmission was "a quart low" so they filled it up and took it for a test drive and all was working fine.
I picked it up that night and couldn't get it into gear again. Eventually did get it into gear, after lots of clutch pumping, but the easiest way to get it in was to turn off the engine, then it would go into gear and the engine could be restarted.
Drove to work this morning and for probably 60% of the gear changes, it was smooth as silk. Then some changes into first and second were notchy and tough to get into gear, with one occasion where I had to turn off the engine to get it into first again.
Primary problem is first and second - three-five and reverse seem generally OK.
This leads me to think that it isn't a clutch problem as surely that would affect all gears? The horrible thought at the back of my mind is shifter forks inside the transmission - there's no grinding going into gear or anything like that. One thing I've maybe noticed (my brain is being hyper-critical about it right now, as you can imagine..) is that when I put it into first, there's a change and maybe a movement in the car/engine note that I didn't notice before.
Any ideas?
With NADA giving trade in value of around $1200, it's not really worth getting the transmission rebuilt if it is that, I don't think..
Old 01-16-2018, 02:19 PM
simonsi's Avatar
simonsi simonsi is offline
simonsi is starting off with a positive reputation.
Sounds like a clutch issue.
Sit the car, park brake on in neutral. start the engine. Listen to the trans. Depress the clutch - you should hear the trans spin down. Release the clutch, you should hear the idle gears spin up again. If you can't hear this then repeat with a long metal bar resting on the trans with the hood up and listen to the other end of the bar (using it as a stethoscope), while someone operates the clutch.
If you don't hear the gears spinning down and back up then the clutch isn't releasing properly and you need that investigated, could be in the hydraulics or the clutch itself.
Easy to say if its not hydraulics then investigation will consist of replacing the clutch, no point removing the gearbox and leaving the old clutch in there.
I'm not sure if there is any adjustment on the clutch hydraulics, I'll be able to check later tonight.
86 M/T problem? kh0432 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 01-27-2018 02:04 PM
Clutch problems. Tranny engages momentarily, destroys slave cylinders, then works fine. What's up? nothercrash 1987 - 1996 F150 & Larger F-Series Trucks 4 11-18-2017 05:19 PM
Clutch to the floor: please help CraigerF100 1987 - 1996 F150 & Larger F-Series Trucks 10 01-26-2017 03:50 PM
M5R2 problems... Mattlewmadeit 1987 - 1996 F150 & Larger F-Series Trucks 56 08-12-2016 07:49 PM
M5R2 problems... Mattlewmadeit 1987 - 1996 F150 & Larger F-Series Trucks 0 07-28-2016 09:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
