10 ft ceiling - Do you have ideas for a short vehicle lift
I've got a large garage with 10 ft ceilings, the garage door is 8 ft high and the track is within 12 inches of the ceiling. Are there any floor-lift systems that can handle the weight of an Excursion/SD truck? I realize I won't be able to walk under the vehicle, but getting the whole vehicle 2 or 3 feet up in the air without using floor jacks and jack-stands would be a huge help..
The concrete floor was a standard 4" slab pour with wire mesh-type rebar.
Thanks!
Thanks!
Most of the low-rise, mid-rise parellelogram or scissors lifts are 6,000 lb. which isn't enough capacity for an Excursion but might be enough for an empty pickup.
You can get low-rise (24-30 inches) lifts in the 10,000 lb. range.
Atlas® LR-10P Portable 10,000 Lbs. Capacity Low Rise 110 Volt Scissor Lift
VLXS10 - Low-Rise Lift | Rotary Lift
I'm considering something like the two above for myself.
Lou Manglass
Lou Manglass
