4x4 issue
Jack each front tire off the ground one at a time. Start the engine, leave it in park and shift into 4Hi. While the tire is off the ground it won't spin if the 4WD and hubs are engaged. If the tire spins freely then something is wrong.
4x4 issue
Ok ill try that.
4x4 issue
It works i think its a bad contact switch or something in the shift motor since it comes on during intotal start up when all lights come on.
Mine dont its a bad contact or switch in the shift motor. I put the truck on a friends lift at his house and put it in 4x4 high and all 4 moved even when i gave it throttle. Toom it out of 4x4 only back spun. I also tested it in his field got a bit dirty and 4x4 works as it should.
bbdano
1997-2006 Expedition & Navigator
04-01-2016 09:33 AM
ironarmscott
01-20-2011 04:29 PM
