Bed components availability for a 76 highboy
There are 6 or 8 bolts that hold the bed to the frame - it just bolts right on. With a highboy having an in-cab tank, you wouldn't need to worry about hooking up a fuel filler tube unless you add an auxiliary tank. Would just be bolt it on and hook up the tail lights.
With a high boy, you have a narrower frame than many trucks of this era; when looking for beds, you could either look for a highboy bed, or you could source one off a truck with the wider frame and either make brackets or drill new holes in the bed to mount it to your narrower frame. Aside from that, it's just a matter of finding a bed that's not rusty and is the right length for your wheelbase. Start hunting around the junkyards, or looking at Craigslist for a donor truck.
I don't recall bed wheel wells nor some of the inner structures being available. Dollar-wise, I think you'd be better off finding and repairing a decent bed instead of starting from scratch.
scottlathrop
26
06-03-2019 08:19 PM
grinnergetter
11-11-2011 06:07 PM
65F100project
08-22-2006 06:12 PM
