oil pressure dances in D and R...
when gas is applied it also levels out. only at idle apologies
Hook up a rear gauge and not an idiot light and see where the pressure is at on the truck. If it is over 7 psi at idle then it could be the sender, if it is under then it could be the pressure is so low that the engine can run fine and get oil everywhere but the sender is bouncing off and on thanks to it.
Your best bet is to rent an oil pressure tester from an auto parts store, thread out the sender that is in the engine now and thread in the tester, Once that is done you can start it and see where it is at at idle speed.
Factory oil pressure sensor is just a pressure switch that causes the gauge to read "somewhere" in the Normal band, or otherwise read low. You can search on here for how to convert it to a real gauge.
dixyboy247
12-12-2007 02:31 AM
dyoungen
09-21-2006 01:48 PM
66worktruck
04-22-2001 06:38 PM
