oil pressure
Old Nov 21, 2005 | 09:12 PM
islanddave's Avatar
islanddave
oil pressure
Hello All,
Just picked up an 88 f150 with the 302. Is there a test for either the oil pressure guage (not a waring light) or the oil pressure sending unit? My pressure seems low, and does not increase or decrease with rpm. I am trying to eliminate the thought that it may be the oil pump. By the way it has 158000 km.
Thanks
Old Nov 21, 2005 | 09:40 PM
frederic's Avatar
frederic
The oil pressure gauge is really an idiot light shaped like a gauge. It doesn't move around based on pressure. Anything over 7psi and it jumps to a predetermined random location.
The oil pressure sending unit is really just a switch.
The real way to test it is with an external oil pressure gauge, attached to the engine in place of the oil pressure sender, and read your real oil PSI.
Old Nov 22, 2005 | 06:11 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally Posted by islanddave
Hello All,
Thanks
...Welcome to Ford Truck Enthusiasts!
…..See you on the boards.
